EWS Fault wiring suspected
bisbee
VIGILUM
Newark Notts
A little help please?
I have an intermittent EWS fault sometimes preventing starting
It is not the ring antenna as it was changed by the previous owner and it only happens when on right hand lock
So should I strip the wiring loom from the starter switch ?
R1200 GS 2006
TIA
Cracking wire where it flexes with steering is the most likely.
Sent from my phone with mangled spelling
is it the battery?
I had a weak battery last month and sometimes after a few failed attempts to start an ews fault would pop up, changed the battery and all ok since
