Exhaust pipe extension ...
Captain Black
manchester
So the story is I've got Vern's world beaters on my 1150 GSA, with the standard exhaust and "Y" piece.
When I bought the bike it came with a 450 mm diameter exhaust extension 2800 mm in length with a slight off 90 degrees bracket with a single hole 1000 mm up its length .
Question is how and where do I bolt it on ? I'm thinking I maybe missing a part.
Does anyone have a similar set up with a photo ideally ?
I want to spare my pannier rails/ indicator the blackening effect, and my panniers when I go to Europe soon.
Anyone ?
It sounds like the set up Vern did for my bike, so assuming a photo is worth a thousand words....
Thanks Baggers's that's exactly it, well almost.
The tube is cut flat so I was trying to assume a fit with a more skywards pointing.
I think it'll fit on that bracket but won't form a proper seating with the exhaust.
Still it will be a huge improvement and avoid most of the blackening on the rails and boxes.
Thanks very much for going to the trouble of a photo....:D
Two threads for you to peruse sir Blacky.....
THIS ONE (rather frivolous)
And....er, hold on, can't find the fekker :blast
Cue "U2"....I've still not found what I'm looking for.....BUT.....here's another one that might be relevant......
http://ukgser.com/forums/showthread.php?22709-Seriously-hot-Remus!&highlight=remus
Ahhh here we go.....I was looking for MY threads, and it was an answer instead :blush
http://ukgser.com/forums/showthread...-larger-Left-Hand-Pannier-how&highlight=remus
Thanks Fanum....
I'm going to have a go with it today. Not sure if it was designed and cut for a remus or standard pipe. My by have the standard exhaust on. I can always get my mate to trim the angle slightly.
Thanks Fanum....
Offer it all up with everything loosened and you'll be pleasantly surprised how much wiggle room you have :thumb
I ended up (in that iteration anyway, I've changed back to cat and stubby now) using some old bracket left over from a previous project, but at one point I had a 10/11 MM ring spanner acting as a bracket :D
