Exhaust popping on deceleration
colesyboy
Back home...in Denmark
Hi all,
I swapped out OEM exhaust and cat for an aftermarket exhaust (dominator) on my r1150rt 2004.
Pops like buggery when decelerating, I found a thread where removing the motronic relay helped, and it did, but still pops.
So apart from that is there anything else I might do to stop the fat old lady from farting excessively?
Thanks for any suggestions !!
Brian
Air getting in or just the fact that the cat and silencer do a lot of silencing...😉
And/or it's running a bit weaker/rougher with the open system on....? Did it keep the lambda?
Perhaps fat old ladies were meant to be quiet...😆
Every r1150 or 1100 that I've encountered pops and bangs on the overrun with the cat removed and/or an absorption tube type silencer....Remus and the like.
Unburnt fuel into a hot exhaust, with somewhere that oxygen is also getting in = combustion in the exhaust. It’s down to a couple of things; fuelling map at that throttle opening and ECU setting, and an air leak somewhere that allows it to suck in air on the overrun. Mine does it just when I crack the throttle after engine braking and apparently can look quite impressive from behind at night… I admit that it feels a bit antisocial sometimes and I’d rather it didn’t do it, but the trade off is worth it for me.
I’m sure it’s weaker and rougher with the new exhaust / no cat setup - lambda not kept - she just sounds dicey, burping and farting so much these days, signs of incontinance!
I’ve had 3 1150’s and every one of them has popped on the overrun, especially with after market exhaust components.
