Exhaust Valve Eliminator Tube
by pass pipe
I would be interested in one of your pipes if you have any spare. or put me on the list if you do another batch.
regards Berg Boxer
If there is another batch made, I would like to get my name down for one. :beerjug:
Stainless can gall (self weld) so use some high temperature anti seize paste on the pipe end and ideally smooth the silencer inlet as well as the tube edge.
Copper grease isnt used as a recommended grease on stainless steel due to corrosion at high temperatures. Molybdenum disulphide grease or Nickleslip is the stuff to use if you can get hold of some. I have used silicone grease without much problem. Possibly any type of grease is better than none. The thing is that when fitting a new car exhaust, no grease or sealant is applied and they still come apart easily enough after many years of use.
Fitted mine dry - easy access to knock out when Santa brings my Akra headers..
Ok. I have the final lot of Exhaust eliminator tubes delivered to me. I have so far got a few names down from the first posting for tubes these are;
Alan R x2
Team Duvet
Yonkyo
Steve G
GPearson
Andrews Adventure
Bangboxer
David Lee
Fluffmeister
Wee Dk
Smuzzy
Major Gadget
All the above should have recieced a PM from me asking about your order. If your on the list and dont now require on please let me know. Anyone else wanting one, please make your intentions known on here and I will add you to my list. If the above orders are fulfilled, I should have about 18 left. These are offered on a first come, first served basis only. Once they`re gone. thats it, no more. Gordon T.
