Exhaust valve is a very specific part; you’d have thought an engineer might have known the difference![]()
just realised what you were getting at
I’m not sure this is the case - it goes through a cycle when you turn the ignition, but,I think, returns to fully open at start. Hence the rather “explosive” startup sound.
I’m still saying (despite the explanations) that the flappy valve is u related to your starting and I’d ask when the plugs were last changed.
It does, it does not stay closed on startup. It cycles and then goes back to fully open. We have one 1200RT where the flap has been stuck open for years, no issues ever with starting. I freed it off, but it is starting to stick again. I had a 1200LC RT that I rode around for nearly a year with the flap stuck open, didn't notice anything. In the end the headers got replaced under warranty. Flap does nothing to aid startup. The flap is for noise emissions only. I would have thought Knutk would know that as he is normally quite knowledgeable. This was also confirmed by the BMW techs who told me that if I couldn't get it replaced under warranty to bosh the thing out, as it wouldn't make a blind bit of difference. Some replace the servo with an emulator to fool the ECU into thinking the flap is there so no error codes. So does that create back pressure then?
I’ve never studied what the flap does and when ( does it close after xxx seconds of run or if you blip the throttle etc ) and if it has changed on later bikes with stiffer emission regs. But what knut said about re burn is 100% valid though and I’m pretty sure Bmw will be doing it. All exhaust systems will generate a reverse pressure wave (back pressure) with or without a flap and manufacturers use valve overlap to allow that pressure to re ingest a % of the exhaust gasses back into the cylinder. The tighter the regs the more they probably use the technology as it means they can maintain cat size and not have to lean off the bike to still get decent emissions.
The Aprilia v4 series of bikes uses a similar valve in the exhaust and it’s documented in their training info as an aid to noise reduction, cat heating, and emissions reduction. I don’t have access to any BMW info but I wouldn’t be the least bit surprised if the valve has evolved in use from a simple noise reduction device in early incarnations to something similar on euro 4/5 bikes. I doubt it makes diddly squat difference to the general running of the bike though.
When I read this thread, it strikes me that perhaps some of the gentlemen in her posting perhaps should do their homework and read up before posting condescending ass-hole comments.
What used to work on older bikes is not necessarily valid for new ones.
The thing is: @Engineers post is indeed relevant.
The strict requirements for the Euro-4 and and Euro-5 means new ways of controlling the engine compared to older bikes.
A cold engine requires a richer fueling than a warm engine.
While this used to be simply a matter of richening up the fueling, the newer emission regs. interfers at all stages of running an engine to a much higher degree than for pre Euro-4 engines.
By closing the exhaust flap, a backpressure will be built in the exhaust flow. This means that when the exhaust valves opens and the pistions try to empty the cylinder for burned gasses, the backpressure caused by the exhaust flap will reduce the flow, and some of the unburnt gasoline (a result from the less efficiency of a cold engine) will be kept in there and be burned on the next stroke. This again allows for the ECU to add slightly less extra fuel to the cold engine and thereby less pollution.
If the flap does not close, this will result in a too lean mixture for the engine when cold, and this corsponds to the symptoms @Engineer described.
Over the last few years, the use of the exhaust flap has evolved. So when asking for information about it's function, the answer will depend on whether the bike is pre -16 (Euro-3), 16 - 20 (Euro 4) or >-20 (Euro -5).
In addition to the CO emission, the focus has also been increased on the NOx part. And the challenge is that while a hot burning combustion is good for reduction of the CO (converted to CO2 in the cat), the same heat is terrible for avoiding the NOx part.
In order to reduce the temperature in the combustion chamber, one trick, the EGR valve used by cars, is to route some of the exhaust back to the cylinder, where the already burned or partly burned exhaust will fill up a bit of the space, thereby allowing for less fresh air and fuel mix. This will of course reduce the maximum output of the engine, but emission control focus mainly on conditions at less than full power. Cars do also have exhaust flap. But serving as noise reduction it is placed way back on the car. This distance from the cylinders means the flap has less effect on anything but noise reduction, but cars have the EGR valve.
In bikes, where the flap is fairly close to the cylinder, closing the exhaust flap and reducing the flow and speed of the exhaust will serve several functions. Noise is still a major part. But the flap also stops / (and even may push back) some of the exhaust (Think of the exhaust as chunk of gases that are pushed in a short burst out of the cylinder. When the ball of gases hit the flap (after passing the cat) it will bounce back. A lot of it will stop in the cat, but some of it will reach all the way and go back in. This will also help for a quicker warmup of the cat. But all of this action must be balanced, as the extra heat is good for the cat and bad for the NOx, where-as filling the cylinder with exhaust will require less fuel and air, cooling the combustion chamber, which is good for the NOx and bad for the CO and CO2 )
For the manufacturer, this is a delicate balance, where they strive to obtain several different goals that contradicts each other (cold and warm at the same time).
Thus, messing with any one of the parts in this chain of events may screw up the entire process.
Also, searching the net for information about how it works may be a pain. BMW uses the same controllers and software for their cars and bikes (hence, ISDA, a car system, also handles the bikes). When you search and find technical information, it does explain a lot of the chemical reactions, timing and formulas etc, but fail to mention if it's being used in cars, bikes or both. Most of the time, the descriptions covers both. But cars are a few years ahead of the bikes when it comes to implementations, thus even if I understand the descriptions and refer to them, I can not completely rule out that it has not yet been implemented to the bikes, even now with Euro-5 (cars are Euro 6).
This bugs the sh...t out of me, and I guess I have to walk the steps to my garage and pull of the mufler on my 1250 to verify my explanations. And if I fall flat on my face, well, being a married man I feel confident that I am capable of handling the verbal abuse that comes along![]()
I'd like to know what you discover, it will save me pulling the silencer off again, I was pretty sure it remained closed after I turned on the ignition and waited a while - what happens when you hit the starter I don't know because I didn't want to run the bike with no silencer attached.
P.S. looking at the flap/valve I would have thought when closed it would provide quite a severe restriction of the gas flow, to the point where it must have far more effect upon the engine than simply noise.
You could observe the servo re determining what it’s doing and when if you make a note of it’s pulley orientation open/closed pre startup.
It might not be a case of open and closed either, it could be anything in between under different situations. ( eg a dynamic mode, compared to a road mode) as well rpm etc.
Actually it is quite easy to whip off the black cover over the top of the flap where the cables join to observe what is happening. Might have a look at the weekend if nobody else has come up with what is happening![]()
Just a note - anticlockwise rotation is open, this is the position with the ignition off and the position the spring would hold it in if the cables broke.
Still havent thought it through properly, the flap is not a primitive form of EGR, its too far away from the cylinder and has a great big filter between and another cylinder also firing - the pulse wont bounce back. The purpose of the flap is a noise reduction measure that can coincidentally be used to heat the cat.
The flap on cars are 2 different things either a noise function as per RS5 Audi or an EGR flap as per lots of vehicles, they are not the same thing.
Im not aware of a cold engine that meets emission standards except perhaps a Tesla, the holy grail with IC engines is to get them to operating temp in the least possible time.
Still havenÂ’t thought it through properly, the flap is not a primitive form of EGR, its too far away from the cylinder and has a great big filter between and another cylinder also firing - the pulse wont bounce back. .
Forgetting the purpose of the valve for a minute, ref a couple of your points.
If the cat ( I presume that’s what you mean by filter ) is a barrier to upstream pressure waves then it would equally be a barrier to the downstream pressure waves as well. That would be pretty bad for the efficiency of the exhaust. It will absorb some going both ways just because it’s a dense material but it’s not unidirectional and by design as unrestrictive as possible.
You imply cylinder 2 firing, blocks any upstream pressure waves reaching cylinder 1 during overlap. When cylinder 2 is firing its exhaust valve is closed so there is no exhaust pulse. The exhaust is in a low pressure state which is really the point of overlap. To use the low pressure in the exhaust relative to the intake charge to pull fuel/air into the cylinder and flush out the old. For cylinder 2 to have an exhaust pulse that influenced overlap on cylinder 1, both cylinders would need to have some degree of open exhaust valves at the same time.
I did some digging last night on the boxer just to see if I could move the debate forward on the servo valve and it’s use especially re euro 5. Beyond it obviously being for noise regs at least in part it’s hard to find anything other than forum chatter. There was a US magazine that claimed dyno testing showed a HP drop of 4/5 bhp on the 1250 if it was always open and surmised it must be being used for some volume matching at specific rpm. I also found from BMW that euro 5 gave them a headache re overlap on the boxer. The e5 regs were much tighter on unburnt fuel being drawn into the exhaust during overlap at idle and low rpm ( as knut was eluding to in his first post ). So they used shiftcam to knock back the overlap at the test points and increase it outside of them. On the r1800 boxer they had to drop overlap altogether to meet e5 and switch to 4 valves per cylinder instead.
So nothing really re the servo valve but clearly e5 moved the goal posts and maybe raises the potential that the valve use may have evolved too. Be interesting to see what the valve is doing and when in all modes.
I think you are reading too much on the internet and taking it as fact.
Yes the cat is a filter of a sort, it does form a restriction hence the reason why the exhaust is often discoloured in the area of the cat and why peeps often say that removing it lets the engine Rev freely.
2 cylinders doesn’t block pulses but smooths them out.
As to the exhaust running at a lower pressure to the inlet, again your applying car technology which isn’t present on a naturally aspirated GS.
