Whitey
The servo motor for the exhaust valve on my 2010 GSA sometimes continues to whine after completing its calibration/test when the bike is first turned on. It seems to happen after I’ve been for a run and the bike is hot.
Most times when turned on from cold the bike cycles the valve then rests up ready for the engine to be started. I thought it was the valve sticking when hot but today I removed the cables from the valve and tied them out of the way while I went for a ride.
On first turning on the bike, it did the calibration cycle (cables went in and out) and was then quiet. But, when I got back from my ride I turned the bike off, then when soon turning it back on again it did it’s test cycle (you can see the two cables moving in and out) then again carried on whurring from the servo motor. The cables weren’t moving, and the noise is an on/off buzzing/whining sound, (like a stuck motor that keeps attempting to move). As the cables aren’t moving and they aren’t connected to the exhaust valve, it can’t be the valve sticking.
So any ideas what’s making the servo keep buzzing after it’s done it’s test cycle?
I haven pulled the cover off the servo yet and removed the cables as I wondered if there was anything I should test with them still attached.
I thought I had this solved and was ready to leave the valve in the open position and remove the cables,, but this has me confused. Any ideas?
If it’s relevant, I removed the can and had eyes on the valve when the cables were attached and the engine was running. It seems to idle at just off closed and then open a bit as the revs rise, but never fully open - a bit over half, 3/4 maybe.
The valve is lose and moves freely by hand when cold.
The same when the cables are disconnected from the valve, it doesn’t seem to pull the opening cable all the way back… not sure if this is right or not.
Any thought on the matter? Is a sticking servo motor a know issue?
