External Jump Start fitting instructions
Not open for further replies.
Da1sycat
Ulsterman
On an island
Chaps, who can advise me which is the positive terminal on the starter motor, is it the one at the top closest to the cover? Also could someone compare their starter fitting and give me a couple of measurements where to drill the hole for it?
Bought the external jump start fitting and Google has failed to find some fitting instructions.
:aidan
If you are doing this on an 1150GS(A)...
Be careful if you read this http://advwisdom.hogranch.com/Wisdom/R1150 starter post install.pdf
The bracket should be installed with the threaded hole towards the rear of the bike.
The pictorial shows it forward and it is very close to the solenoid shell which is battery negative.
I informed Tony Lorenzo long ago about this but never got an answer back.
It should look like this:
