couldnt find it anywhere else ... so just some advice on how to remove brake disks...
1) get a fine flame torch (like the on selling in Wickes at the mo.)
2) get a good quality impact driver
3) heat up each disk bolt in turn ..to 'over' 80 deg C ( careful so as to not damage the wheel hub finish)
4) grab driver and locate it in the bolt...and carefully hit it with a hammer (making sure you got the right hex bit and its inserted in the bolt fully)
5) after its shifted a bit ....wind it out the rest of the way with an allen key.
job done! ..... the impact driver is a lifesaver
