How did it happen...............well there is a story!!
I was about 100km outside of Ulaan Baatar off road, only doing about 15kph on what I would call a mogul field, came to the top of a deep one, pulled left to miss and the front wheel when down broke the Metal Mule screen, bent the left pannier frame, bent the gear lever and cracked the headlight and yes I did have engine bars and a headlight protector.
Funny really as i came off at about 100kph a few days earlier on a track and did no damage whatsoever except for scratching the left engine bar.
Out of the four types of bike to go (new Tenere, F650, 1200 GSA and 800 GS) the 800 was the most reliable and best all rounder, not just in my opinion. The Tenere were not good and one did not make it, they ate chains and sprockets, cush drives were made of putty, head bearings were crap and they drank oil as if it was going out of fashion.
I am now doing a minor rebuild to mine, I need to replace the rear wheel bearings, replace the oil to the front forks, I have had the ohlins rear rebuilt, the lambda sensor needs replacing, the Rhemus pipe bracket split and I am replacing the original and the right heated grip stopped working on the last day into NY and a bloody good clean!
One pain was the top hose, this was repaired by recall before I left but kept failing and in the end I glued it and jubilee clip which is ok but I will sort out correctly now, obviously BMW still have a problem here.
Hats off to the scott oiler, one sprocket and chain (original) to South Korea, approx 16,000 and really the chain and rear sprocket would have been ok for several thousand more, the front sprocket was worn however.
Do you wish that you never asked........?
S
