stephen.stallebrass
Apart from the two wheel nut sizes do you need any more ?
How do you break the bead ?
Some people say 3 levers is best but I've found 2 is fine but a bead buddy is a helpful tool to have.
Sometimes just standing on the tyre will break the bead but be careful you don't ruin your brake discs and or bobbins: front wheel beads are normally easy to break. But rear wheels or big front wheels I use the side stand to pop the bead. Put it on centre stand - its a good idea to lock the front brake and strap the centre stand to the front wheel to prevent it collapsing. Put the edge of the bead under the foot of the extended side stand and lean the bike over to pop the bead. Most tyres will break easily this way. Some that have thicker side walls like the Heidenau K60s can be a bastard to break. I've had my whole F800GS balanced precociously via the tip of the side stand on the bead and bouncing it up and down to break the bead... patience, technique and plenty of lube are the key ingredients.
