Fast Way Foot Pegs .
Sir James
Rear Stab Vest Only ....
Independent State of Burtoria ...
I've fitted a pair of Fastway foot pegs to an 1150 ADV , i used the search and printed out the pictures posted , ( thanks Whatton ) . Every thing went really easy and now their on , however i was wondering if you have to fit the studs on or can you leave them in the box ? Will the peg be to slippy without them or has anyone fitted a rubber cover or similar ? TIA , James . :thumb
What I did was bought another set of BMW footpeg rubbers (about £12, I think) and pushed these into the Fastway footpegs. This gives you a wide, damped area on which to sit your feet for normal road-riding, with the added advantage of being able to quickly push them out if you're tackling anything off-road... then you get the superb grip of the studs, even when wet and muddy. It really makes a difference off-road... having the confidence of knowing that your feet aren't going to slip off the pegs at a crucial stage. The wide pegs also give so much more 'feel'.
James Burton said:
Thank's for the advice. :thumb
I've put the short at the front and long at the back and might try the rubber pieces later .
:beerjug: James .
You'll need the studs in James for all the off roading we're going to be doing on our trip to morocco :eek: nothing worse than wet muddy boots slipping about on the pegs :D
Nooooooooooooooooooooooooooooooooooooo !
:yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes :yikes
I wonder if Auto Glym do a travel pack :nenau
I'll have a practise tomorrow , if i see a puddle i'll go through it ( slowly of course ) :moped:
Just got my horn to put on now :thumb
