plasmatron
I'm prone to having blinding flashes of inspiration which lead to expensive impulse purchases and overly ambitious plans, or as my wife calls them "bloody stupid ideas"...
so I suddenly had the idea of taking the spoked wheels that I've already got for the GS and putting either full offroads or dual purpose tires on them for offroad/enduro use, then, getting a set of 1200RT wheels slapping some BT014's in perhaps 120/70 and 170/60 sizes and giving my GS an optional supermoto mode...
as near as I can tell the RT wheels look very similar to the GS's size wise... and whilst the rotors on the RT wheels are 320mm compared to the GS's 305mm, it looks to me like the mouting tabs on the RT's rotors are taller and that the actual mounting location is the same, so assuming they aren't wider or something, they may just accomodate the GS's 305mm rotors just perfectly... then it's only a question of the width of the front wheel hub / spindle being close enough to the GS's and I'm fairly sure the rear is just a straight bolt on, perhaps needing the RT's shorter/longer bolts... it seems that the clearance off the swing arm should allow for the 170 rear, especially since the AC Schnitzer wheels for the GS use a 180 rear...
and there you have it... the 12GS supermoto, perfect for destroying the bumpy, super tight, low grip twisties that are 80% of local riding terrain... probably look pretty cool too IMHO... I know the purists are going to condemn me for all eternity for even suggesting this, but it's a matter of taking the ultimate allrounder and tweaking it for local conditions... and I get to muck about with some spanners...
Question is:
- how to cope with the 2" lower front ride height?
A: bolt a spacer into the top of the stock front shock mounting... not much room I'm sure...
B: Wilburs front shock with added ride height adjuster... perhaps custom length...
C: RT or ST stock front shock
D: ignore it and see how badly the increased rake/trail effects the handling...
Question is:
and fit more crash bobbins
