Completely agree on the risk of fitting the wrong size (usually the next size down). Bought a new fd drain plug because of exactly thatFWIW Rodin, I really hate Torx, they are supposedly better for surface area and hence torque to undo, but they seem to “cam out” and chew up far too easily especially if at a slight angle, plus it’s easy to accidentally fit a slightly smaller tool into a bolt that the one it should be, causing damage eg T27 bit into a T30 bolt. If you start to chew up a Torx, stop immediately, go no further, reach straight for the dedicated “damaged torx” removal kit.
Thanks for the link to the broken tap extractors, something else to add to my arsenal of “damage limitation weaponry”.![]()
. And yes, care is needed when inserting them... I'm kind of with your thinking!Sent from my SM-S908B using Tapatalk
