Ref. 2015 R1200GS lc.
Ok. I have measured the drain plug and am I correct in that it is M12x1.0 ( fine thread)
The drain plug was exceptionally tight as is the filler plug, the result is the threads are damaged and I need a tap to clean the threads. The filler has not been removed yet, still under penetrating oil and heat treatment. I am very suspicious as to how this has happened.
Of course this has come about because I just had to have a look at the drive spines. top one very clean but no grease from new and the bottom spline tight with corrosion and peeling paint under rubber boot. 15k on clock.
Thanks.
Thanks.
