Final drive oil amount
Danny996
Member
Eastbourne
I have a 2011 GS1200 with a vented FD. Is the FD oil quantity 200ml for vented versions and 180ml for the non vented?
Ah ok thanks. I was looking it up on this forum and I seemed to come across some people saying 180 and then the post in the photo recommended the previous amount of 200ml… just thought I’d double check what amount people were using for the later vented models.
If it was me ,,, I would go with what Mikeyboy recommends !
I have a 2006 adventure.
1 ltr of oil.
I have always put
800cc in the gearbox.
200cc in the final drive.
Saves wasting 20cc 😁
I'd say the reduction from 200ml to 180ml was a kind of grasping at straws effort by the Mothership. The F1 lads wouldn't work down to 20ml tolerance... well maybe! :ROFLMAO:
I notice my 2008 "sweating" a bit around the seal in very hot weather and I did buy a new OE seal but it wasn't enough to make me change it, I'd need a couple of good drips before I'd consider getting the tools out. And then there's always the risk of frying pan to fire :ROFLMAO:
I'd say the reduction from 200ml to 180ml was a kind of grasping at straws effort by the Mothership...:ROFLMAO:
I think you are spot on there. "Oh it leaks? Put less oil in it. Still leaking? Use even less."
They did this on the G450X. The design blew oil out of the crankcase breather, so they recommended putting less oil in the engine. The updated quantity barely touched the minimum level mark.
I not about to go digging to share the links for everyone, but if you care to go down the rabbit hole, there is a lot behind the oil qty reduction. It's actually quite interesting, depending on your interests.
The bottom line is, you can't have too much, it will eject itself as required! Admittedly, there could be consequences to that 'self adjustment'. So beware!
Personally, I've done the obvious thing, 190ml... approx - it's always approx!
I may end up eating my hat, but so far, so good
Book says.
200ml for a brand new dry unit. Or a rebuilt unit.
Which maybe Mikey boys comment? That's what he does. Rebuilds bevel drives.
I can't remember the official capacity ever being 200ml for a change on any post 2003 bike.
If you put in 180ml on a change. You will have 200ml in there. Because that thick oil sticks like shit...
Unless you leave it draining overnight on a warm summers night. And then it will still be wet inside.
I must have changed oil on thousands of bevel boxes. Tens of thousands.
I've always gone with 180ml. And I've never known a problem with that.
And I see no reason to change.
The reason for the original reduction in oil capacity was to reduce the chance of seal failure/misting etc,due to oil expansion and lack of expansion space on non breather units.
This was predominantly noted at high temperatures and more so at higher altitudes such as alpine mountain passes.
Get to the top,stop for a photo and oil pissing out of RH seal usually.
However,after the reduction in capacity to 180mm I started to see a pattern of premature wear on the inboard pinion bearing.
200ml reduces the chance of oil starvation to this bearing and seems to be a good balance to also reduce the chance of oil misting.
Hope this helps,
Hope this helps,
I know this is why the breather was introduced.
The fill for new and rebuilt units is 200ml. It always was and still is.
Maybe early workshop manuals stated 200ml for refill too. Not taking into account that the oil wasn't fully drained. BMW make these errors all the time.
But when doing an oil change, the recommend re-fill is 180ml. As there will definitely be 20ml still in there. If not more. Which takes you to 200ml.
So putting 200ml in al already wet unit will make it a 220ml total.
Perhaps 220ml is the magic number after all. 🫤
