Final Drive UJ's
Popeye
weaving thru' the GATSO's
Got the back end off the bike to do the paralever bearings and thought I'd check out a few other parts for wear & tear whilst I was at it.
This is the universal joint as it is removed from the final drive assembly, by which I mean at the rear wheel end of the drive shaft rather than the gearbox end of the drive shaft.
When I move it from this position ....
http://
To this position
http://
It feels quite notchy. All my instincts tell me it should feel completely smooth. There doesn't seem to be any play, as far as I can tell, just a notchy feeling.
If this isn't as it should be are the individual bearings replaceable or is it a sealed assembled unit.
Mine did the same (the same UJ), a bit rough movement at one spot, but just a very small effect. While the integrated UJ on the shaft was completely smooth.
Can't tell you if it means it blows up after 10K or not. But I reckon it should have some fair amount of lifetime still left if it doesn't have any slack.
Sad thing is that you can't buy separate UJ from BMW dealer - you need to buy COMPLETE shaft (with UJ on both ends) - loads'o'£££.
So if it blows, it's better to hunt for s/h unit sold separately. Good thing is that it's not that hard work to replace one as you've already noticed :)
Dito here. UJ on FD side felt notchy, other side was ok. Had the UJ bearings replaced by a company specialised in servicing driveshafts. Said they had done quite a number of R11xx bearings so far. Mine are good as new now.
