R100GS PD Drive shaft re-engage to final drive
Mark_S
Wiltshire
Hi All,
I'm trying to re-engage my PD's driveshaft to its final drive. The swinging arm is off the bike and the bevel box is still connected to the swinging arm.
I'm guessing that the bevel box needs to be disconnected from the swinging arm and then the shaft can be re-engaged, then bevel box back on....but I'm trying to avoid that.
Any sensible advice is appreciated.
Mark
sometimes the long way round a job is easier and much less frustrating.
plus you can lube that end of the shaft ( unless it runs in oil )
Just keep trying. Get the splines lubed up and at the right angle and it will go in..keep repeating..it will go in
i have been trying for a while, they sort of engage, i can turn the shaft and the FD output turns, but its not engaged. i think im going to submit and follow Mikey's lead.
thanks for them advice.
Boy, am i hissed of with the smell of gear oil........
