Finally finished lights!
pitrat101
Cheshire
After finally finding some nice angel eyes/halos with optional fog led. I fitted along with hids which I have had for a while. Rather happy with results, just got to see how they are in the dark now!
You're going to struggle if you need to leave it plugged into the mains though :cool:
Ebay! only £40 they are for a car bumper but thought they would do the job! 89mm diameter!
eBay item number:
291912992316
Hope this helps
Yeah! research and more research then measure twice, twice again and go for it! Haha. Now I need to ride the bloody thing! seems to be an expensive ornament at the mo! but will get a run to the bike show in a few weeks!
Looks good. Did yours come with the 3 modes (dim/bright/strobe) for the central light?
I've got some similar lights sitting in their box waiting to be fitted, but not sure how to proceed with the wiring/switching
How did you wire yours up? Separate switchgear or triggered off canbus?
I had the ones with 3 modes but didn't like them, found them a bit small And had to cycle through modes, the twin switch was naff. I sourced a grey switch to match switch gear and wired fogs via relay/switch. Fitted an led 501 bulb to sidelight that was canbus ready, just chopped into side light wire for halos and the resistor in the bulb does the rest! no faults at all!
Nice n neat. Where did you get the switch?
I have 4 of the cheapy U7 spots with the halo rings. 2 for near the indicators and 2 for the engine bars...well it is coming up to christmas :)
Wired them up together on the bench to get them in sync with the three modes and noticed how quickly the suplied double switch wires got warm. So now on the hunt for suitable relays and connectors. I want to be able to switch the Halos and spots independently, so I think I need to have 2 separate switches and relays, but electrics is not my strong point.
Also planning to give the casings a bit of a going over with some clear silicone as there no way they are waterproof as claimed.
These look similar to the ones I have (though I later added the halo rings). LED spot lamps with 70mm OD halo rings.
http://www.ebay.co.uk/itm/2x-125W-M...824426?hash=item2375991e6a:g:ohwAAOSwn7JYEyAc
