Afternoon all
Loads of postings here about the pros (and cons) of the AF330 meant that I held off buying until a couple of friends fitted them to their 12GSs and were very pleased with the results.
So, I now have one to fit to my 1200 GSA and, because it is designed for the GS which does not have the upper screen brace and is made of thinner perspex, the coverings (part 5 on the attached image) are too long. Would buying just GS versions of these bits 46 63 7 673 913 and 914 solve the problem or would I have to buy the matching inner parts 46 63 7 707 221 and 222 as well?
Alternatively, how did other AF330 + GSA users solve the probem?
It seems that making a spacer equal to the thickness of the upper screen brace won't solve the problem because the Givi brace takes length out of the clamping bolt but in the wrong place in the assembly IYSWIM and taking even more length out of it by adding a spacer in place of the OEM upper brace will shorten the clamp even more, possibly to the point that the inner cap nut can't be fitted (not the end of the world) - unless others have done just this with success and no problems.
Regards
Richard
Regards
Richard
