AF330 first impressions
I took the GSA plus AF330 for a spin round Wales at the weekend - Welsh Nation Rally - and covered about 800 miles.
Lower portion of the AF330 was left at the lowest setting on the OEM adjuster and I tried various settings for the moveable section.
I experienced no helmet buffeting at any height setting for the moveable portion irrespective of road speed. There was no reduction in the air flow felt on shoulders but this is not a problem as dealing with the helmet buffeting was the primary objective with opportunity for increased airflow to the face a secondary objective.
Airflow to my face seemed greater, but not excessive, with the moveable portion at the lowest setting and I think that even at motorway speeds I might be able to ride with the visor fully raised. I didn't try this for fear of losing a contact lens or encountering a high speed insect. In fact, there seemed to be more insect impacts on the visor than usual with the moveable screen at its lowest setting but that may be a false memory since it's nearly a year since I encountered any insects when riding. I think that the screen would require raising if riding in torrential rain but although I encountered such weather in Wales (no surprises there) I didn't feel like experimenting with the screen height.
It seems to have been a successful purchase. I'm not going to re-fit my OEM screen to see if adjusting it to the lowest setting results in the same reduction in the buffeting as I always used it on the highest setting with a Wunderlich airflow thingy
As you will see from earlier posts to this thread, I found that it was beneficial to buy the GS fixings 46 63 7 673 913 and ..914 rather than clip the pins off the GSA versions. Also, the Top Hat bushes were replaced with some stainless steel tube. This latter change may not have been necessary.
The only minus is that the front edge of the lower portion protrudes just far enough over the lamps to reflect the light which is a bit distracting at night. I believe that I have seen an eyebrow thing that fits to the top of the lamp unit - like the sort of thing that Morris Traveller's sported many years ago. Is that possible?
Thanks to BendyToy for listening to my ramblings and for helpful suggestions.
Richard
