Is it normal to have to remove a few links from a new chain to get the correct length? If so, whats the best way to go about it?
ie - how many links to remove - should I go with a length that is at the shortest setting assuming it will lengthen over time? (I've changed the sprocket size too, so can't use the old chain as a guide)
also - is there an easy way to remove the links?
Any help would be greatly appreciated!
