Fitting Touratech Spotlights
kazntone
Sheffield, England
Hi Have just got a set of second hand Touratech Spotlights for my F800GS.
I have downloaded the fitting guide but dont feel confidant fitting myself after taking the pannels off and having a look.
I have spoke to Raindow and they would not commit to a fitting price on said its £60 an hour and would not offer a time to fit.
I am looking for someone to do this in the Sheffield area.
Any ideas guys? I have all the relays and cabling.
I've got the Twalcom spots on my F800GS from AdventureBikeWarehouse, which fitted them for free... They do free fitting for all their Twalcom products. Rudimoto did a good job fitting mine, don't think it took more than an hour. Give them a ring and see what he'll charge you. Alternatively, flog the used TT kit and get yourself some brand new Twalcom from the above.
http://adventurebikewarehouse.co.uk/
Fitting Lights
There is a guide in one of the stickys however FWIW and on the assumption they are the same as these mine are fitted like this:- auxiliary fuse panel fitted under behind the battery, this is controlled by a switched relay from the canbus. The supply to the lights is from the battery and switched via a relay fed from the fuse panel.I fitted the relay under the nearside panel under the air intake. The light mounting is sandwiched between the beak and adjacent panels.
