Fork sliders
Martyduncs
Worksop, England
Does anyone know if the small casting which caters for calliper, abs sensor and wheel spindle comes off the aluminium tube? It is defo two separate parts with a screw going upwards from inside the wheel spindle hole.
I have a damaged casting and have bought a second hand slider but the tube part is pitted so I would like to change the casting only. P.s. it's a r1200gs. Any ideas PLEASE.:beerjug:
If you look here http://www.realoem.com the parts diagram shows the fork slider as one unit. So they can't be bought separately - only a vice and a huge stiltson wrench will tell you if they actually separate.:eek:
Alan R
Alan R
Thanks Alan, I have got a big vice and some 48"stillys, to be honest I would like to try a more softly softly approach. The screw (m8x25) going upwards is not a drain type screw so there has got to be a way
They might be bonded with super strength anaerobic adhesive with the little M8 just to line things up.
If they are bonded some heat may well shift them.
I'm a broken record on this but another option is mask up the legs and have the casting anodised or powder coated.
