@hi222;The 1250 GSA feels the same as my prior 2017 GSA except that as your mentioned the crashbars are redesigned as also the sides but this is only cosmetic.THe ESA suspension is slightly different as the new one set on max/dynamic seems to be a little taller then the old one set on 2 people as the pegs drag later on the 1250;GPS showed 57 degree max lean without crashing...
The real difference besides the slightly better brakes and cleaner to shift gears 1,2,3 as 4,5,6 were already perfect to shift on the older one is the ENGINE...
Vastly more powerful as in TORQUE.On the same dyno as much as a supercharged Kawa H2 as in 140 NM @ MOTORRAD @ MO even 145 NM !
As in GPS topspeed of 133 vs 137 mph / 214 vs 220 km/h the 1250 gets there much faster but around 8000 rpm the power starts to drop off and the big barn door would need more power to go faster which it can't with the bags and topcase causing to much drag...it starts to get frisky around 120mph/190km/h with the bags clearly stating not to go faster than 110mph/180km/h.THe 1200 did the same until I bought Ohlins TTX.I won't do it again though as the yellow triangle showing a ESA fault code is just too annoying.
High speed stability is definitely a trade-off for the quicker steering due to less trail compared to the regular GS...
Otherwise it is a great bike that is a lot of fun to ride in the twisties and accelerates hard and has performed flawlessly so far...
But I still dream of that R1400GS with 160hp/150nm 20 kilos lighter with 17 inch CF wheels and a lower superbike handlebar...
Until the factory gets of their arse and gives us the XR version of the GS I maybe try a regular longer trail GS with the Alphatechnik.de OZ wheeled and 320mm disc 17 inch conversion...who knows ?
All in all a great bike the 1250GSA.There is nothing else I'd rather have !
Strong boxer,Telelever,driveshaft,quick steering,practical,comfortable,big enough tank - what is not to like ?
For the dirt or track there is better stuff...but for the street the 1250 is definitely the best bike on the market !
Totally happy even with the weave because how often do you ride 226 km/h on the tach ?
I rather have a quicker steering machine at real road speeds up to 100mph...
What is also amazing is the fact that my buddy on a AC 2012 1200-GSA running at the same speeds on our Mexico trip mostly between 85 and 110mph got worse gas mileage than the bigger more powerful and more torquey 1250.Filling up every 200 miles or so he mostly had to put in 3 liters more !So real tank range is around the same despite the new one only holding 30 vs 33 liters...
And yes we met a few English guys on the Baja mostly on beemers being on a trip being followed by Nick Sanders in a Ford truck...
