gps mount
I used the bmw scotland mount (small version) in conjunction with the Garmin Motorbike Kit & a 2610. The Garmin motorbike kit comes with a 1A fused lead to connect into the GPS, and bare wires for the power and a 2.5mm mono socket for audio. Am not sure if the fuse is really needed given that the switched power from the BMW is electronically fused, but I left it on anyway.
I fitted all this, Autocom and the BMW front power accessory socket & y-lead at the same time, and removed the fuel tank in the process to fit as per BMW instructions (although some would argue its not really necessary). I tapped into the BMW y-lead using the Maplin battery connectors previously mentioned here, and put mating power sockets on the GPS and Autocom flyleads so they are not hard wired.
Am v impressed with the GPS mount from dutchman, it does stop the screen from coming all the way down, but so what - I keep mine on the high setting. But would suggest staying away from the "large" mount as it is very floppy.
