Front beak out of alignment
Same.
Mine is also out of alinement in the same way yours was. I came to the same conclusion about what to do about it. I thought I would need to move one of the nuts welded to the frame to allow the nose mounting arms to move. But after reading the above post you suggest that there is some movement allowable with the bolts just slackened off?
I'll try the same next weekend.
You will need to remove the front two side panels to access the two screws that secure the rear end of the two cast alloy arms that hold the front end in place as well as the two screws coming from the central mount.
The side plastic panels are the ones with the BMW roundel badge, 4 screws and a plastic pit-pin (or whatever you call it) for each panel.
I slacked off everything I could find.
PM if you need to help.
