Front brake lever click
ShakeyGS
S K P
The Garioch, Scotland
I recently changed my front brake pads, fitting Brembo scintered pads this time.
To fit them I pushed back the old pads to make space, venting excess fluid throught the bleed nipple.
More recently I noticed the lever was coming right back to the grip so I gave it a good few pumps to stiffen it up (oooerrr!) and held the lever back with a velcro strap overnight a couple of times. This improved things a bit but still not ideal so I decided to bleed them through with some fresh fluid (I did a full bleed including exercising the ABS last autumn) and I did get a few bubbles out of the right caliper but not much.
Again there is improvement so I think I’ll do the full bleed again BUT now I can feel a click through the lever when pulled back half way. I’m wondering if that might be a worn master cylinder seal folding back under pressure :nenau
Anyone else experienced this?
Do I need to overhaul the master cylinder at 27000 miles?
I do use the “old fashioned” method although I have a line with a spring loaded non-return valve so I don’t have to reach over to close the bleed nipple before I let the lever go.
Ummmm. Probably?
The click was a red herring eliminated with a bit of lube. I think I’ll get a second pair of hands on the job and have the nipple opened and closed. :blast
you should not have opened the bleed nipple.you now need to introduce some new fluid and bleed the brake,imo from what you have posted obv
Presume you mean when I put the new pads in. I wasn't keen on pushing oil back up past the master cylinder seals in the “wrong” direction.
never ever have i opened the bleed nipple when changing pads,and ive done hundreds in my time :rob
OK folks, this is really starting to bug me.
With a second pair of hands we've bled the front brake to the tune of about a jam jar full and there is no difference.
I have attached the GS-911 and run through the ABS bleed sequence too. Here's what I'm not sure about....... As the GS-911 runs the ABS to purge it, you have to operate the brake lever for 2 seconds at least 3 times. It isn't clear to me whether the bleed nipple should be open at this point but given that we've just completed a manual bleed cycle, mine are closed. Am I being a numpty?
Thanks to BoxFlyer’s youtube channel I believe The bleed nipples should remain closed during the running of the ABS part of the cycle.
