Front Cover - Quick Question?
Howard J
Who?
Chester
Just in the process or removing my front cover to re paint, I have almost all the bits off, but not sure about what to do after I have removed the small black box at the bottom of the cover? There is a what looks like a bearing secured with a reverse torx bolt and I can also see a circlip, do I need to remove any of these to get the front cover off?
Also, when I come to put everything back, what is the best way to get the alternator belt back on?
In the garage............waiting? thanks guys :augie
Looking forward
Mate, you may want to consider some protection (oh er missus) once you have sorted it so you aint repainting. I know it looks like I am plugging my own stuff :blagblah:blagblah so I always say buy something like this (not necessarily mine) as it really does protect the front of your bike. There are lots on the market or alternatively use ACF50 which a lot of the lads recommend - I don`t use it myself but I am under no illusions that its brill.
Hope you get it all sorted.
mark
www.cymarcbikepart.co.uk
[/url][/IMG]
Mine slipped off with out using any pullers,the bearing came off with the cover
Is that your own crud catcher on there? I like the look of Mark's but would prefer something in aluminium similar to the bash plate.
Here's a better picture Andy, plate is made from 2mm alloy and rivited to bmw sump gaurd:thumb2
Tidy job:thumb
If you were doing it again would you use anything thicker than 2mm?[/QUOTEI
It was the thickest alloy the folder I was using at the time would bend, and to be honest its never been a problem,but 3mm might look better!
