Front disc bobbins
scot
Member
Spain
Hi guys has anyone got a diagram of the correct fitting of the bobbin ,washer and wavey washer I just seen a video on YouTube and the guy put the bobbin on the wheel then disc then washers mine wasn't like that 09 GS
Does your 09 not have the bobbins riveted onto the disc, like my 2010 bike?
Anyway, previous bike had discs with domed heads like the ones below.
The bobbin is fitted from the outside.
No it doesn't have riveted bobbins but not that set up either I have the bobbin one solid washer and one wavey washer the bolts have a flat head
Different brands of aftermarket disc do them differently, even the aftermarket brembo vs oem brembo are different bobbins
So I have put the discs on as I removed the old ones solid washer,disc ,wavey washer ,bobbin ,bolt but I don't feel any movement in the disc I just feel like something isn't right I thought if it's bobbins and washers the discs should be floating
I've looked at the exploded parts diagram on OEM Parts and in my Haynes manual, neither show enough detail. The Haynes manual does make a point of reminding you to make sure the bobbins are the right way round.
I know that might not be too much help but hopefully you will work something out
Thanks I have tried them both ways and put the old discs back how they were to see how they were so I presume they were right I have put it all back together with new discs all seems ok maybe I am overthinking 👍
