jimbogs1200
I have been told that there is foam behind the plastic cover at the front of the engine, supposedly for noise deadening!? I was also told that this piece of foam gets wet and stays wet...and should be removed; this will help stop the corrosion that is often seen in this area... Any truth to this?
You're damned if you do, damned if you don't kinda thing
