NO.
Most of the general use cap head bolts I use at work are 8.8's but I do use 10.2 , 10.4 and 12.4 bolts ranging from M6 to M24. Never assume that a cap head bolt or screw is high tensile. Look at the head and see what is stamped on it. As the OEM bolts do not have a head stamp, it is wise to replace a damaged OEM bolt with another OEM bolt for the same application. Just guessing what to use can lead to all sorts of problems.
I would not replace a shock absorber mounting bolt with a stainless bolt, as it may not have the shear strength to cope with the forces that are being applied to it.
Steve
