jonesai
I am fitting - or should I say trying to fit a s/s clutch hose to my 1999 1150GS. According to the forum this should be possible by removing the rear shock and the clutch slave cylinder, disconnecting the clutch hose allen bolt and pulling the new hose through having cable-tied old and new hoses together.
Before I even get that far the lower allen bolt on the rear shock won't budge.
. I have removed the shock top bolt and tried a long handled allen key with plenty WD40. Can't get to the bottom allen bolt with a ratchet spanner and allen socket as not enough clearance.
Looks like the silencer will have to come off and then I can attack it with a impact wrench. Should it be necessary to remove the silencer? - looks a sod of a job as everything is rusted solid. Any (sensible) suggestions welcomed.
. I have removed the shock top bolt and tried a long handled allen key with plenty WD40. Can't get to the bottom allen bolt with a ratchet spanner and allen socket as not enough clearance. Looks like the silencer will have to come off and then I can attack it with a impact wrench. Should it be necessary to remove the silencer? - looks a sod of a job as everything is rusted solid. Any (sensible) suggestions welcomed.
