Front tyre change using cable ties
ButtonMoon
North or South.
Changed my front tyre using cable ties at the week end, it took ten mins to cable tie the tyre then slide it on the rim, it took longer to cut the ties ! if you try this leave a bit of a gap between two ties and keep them a little slacker than the rest, so you can pop it over the tyre sensor first. Here's a pic. Ignore the rim scratches that's where it fell off the work bench after I took the old tyre off. :)
