peterbiker
Hi Guys
Has anyone had this problem?
I have an 08 GS 1200 (not the Adventure) so has a cast wheel. I seem to always be losing pressure in the front wheel. I changed the tyres in May before a trip to Germany and every week I have to top up the pressure.As it happens I had to do it before the tyre change. Now I have to put air in every day!! I have looked for leaks ie. soapy water around the valve and the tyre but no sign of air leaks. The tyres are metzler Tourance and I have no problems with the rear. I did get a pucture in the front a few weeks after the new tyre was fitted and had it plugged (you know tyre off and repaired from the inside) I have checked the repair several times and there is no leak there. Any ideas??
