Hi all, I’ve recently picked up a second K25. I have a 2007 in France, which has previously had its fuel strip replaced. The one I have bought in the UK (2005) has dodgy fuel level readings (of which I was aware when I bought it); it reads Full for around 120 miles, then jumps to around 1/3 full and continues to read lower as the remaining fuel is used. I figured that the fuel strip was dodgy, so ordered the revised version from Motorworks. I’ve just pulled it apart to fit said revised fuel strip, but found that it has a float sender. On this sender, the float hits its top stop at around half a tank, and stays there submerged with higher fuel levels. Overall, I can work with this, as it reads sensibly at lower fuel levels, but I was wondering if this is normal?
