Hi all
Does anyone know the inner and outer diameter of the oem BMW fuel hoses inside the tank, between the fuel cap and fuel pump plate?
I believe it has 5x10 written on it, which I think means 5mm internal, 10mm external, but I could be wrong!
Also, are all the hoses the same dimension (e.g the long inner tank ones, ones connecting the pump to the fuel filter and the external two to the fuel line dry break quick release unions), or are they different bores?
I’m hoping I can buy 3m of the stuff and replace everything at once.
Thanks in advance!
Mike
Thanks in advance!
Mike
