Fuel pipe disconnects
Greg Masters
'Don't mess with me' Member
Moderator
Moderator
Middle England
Can anyone post a photo of the fuel pipe disconnects in situ (as fitted to Adventures and later 1150's)?
Greg
As fitted to my 1100. Worth buying a couple of extra O rings just in case you split one.
Sorry to revisit this topic again but I ordered my disconnects from Cooper Reading a while ago and received them yesterday in the post.
The problem is I don't think I've got all the parts I need.
They sent two plastic bits (with metal springy bit on the end) and four tacky looking rings to seal it with.
From the picture posted previously it seems as if I need some metal 'bolt's' which will will screw into the other end of the fuel pipe and connect to the plastic bits.
Is this correct? or am I being stupid?
Thanks,
Andrew
Check this thread.
The 3rd posting down lists all the parts and part numbers you need.
Greg
