Fuel tank water drain hole
Santa-2512
Omnipotent one
North Pole
Think mine may be blocked...
I tried pushing some wire down it, but only goes about 4 inches then stops.
Is strimmer cord strong enough, or does it need welding wire or similar?
How far should it go to confirm its clear??
If i try going from the other end, which tube is it? there are two ;)
Small syringe! Use it like a sink plunger
Sent from my SM-G920F using Tapatalk
Used petrol strimmer cord on mine, its tougher. Less chance of doing damage to pipe and sprayed a little WD40 down as well to lube it, went all the way through no problem
Might try that tommorow :)
where about on the tank is this hole .
Ideally you want to try to blow it back out the way it came rather than further down the pipe :thumb
It doesn't really matter no harm will be done.
One is a breather and the other is the drain...
Cheers :) i'll probe both then ;)
Nice to meet you yesterday Neil,
Ive contacted Mikey, just got to get te FD off now :)
