Full size L.H. System case on GS
(RIP) sherpa
Thurgoland
Been playing around with this one for a while and after dismissing the Wudo pipe adaptor at £140 ish I visited my local exhaust fabricator who helped out for £30
The box now sits under a full size system case and the whole lot takes about 1/2 hour to fit (only intend on leaving it in situ whilst touring)
The bracket is very simply made up of two pieces of stainless bar suitably bent.
the blocks on the system case are to allow it to sit in the standard GS mount rather than fabricating something on the bike.
Will be fully tested next weekend in Scotland
If it works for you then nice one :thumb
I bought a Wudo bracket for a lot less than £140 - who quoted you that ? As usual the German instructions weren't that easy to follow but it went on with the help of a few other GSers.
Good side is that it is well engineered and does the job as advertised.
Bad side is that it leaves a gap between the can and the heel guard.
I fitted mine for the Garmisch trip but have taken it off since returning home as I only use the cases for long trips and not day to day.
