Deleted member CB
Davedyer, you could be right, this is how it came from BMW, nothing has changed other than a new battery. I would have thought that adjustments would have to be made for it to "go past" full throttle? It doesn't seem to be consistent, after a reset it might not cut on full throttle, then 20 seconds later it probably will & carry on doing so. Strangely it doesn't seem to be exact, it appears to cut at slightly different times but always near full open.
Thanks for the idea though, I'll try & check that out, the more theories the better!
