Cook1e
Hi Chaps,
It's not the most intuitive software, is it... I've been getting the hang of it slowly but surely, but I am still a bit bamboozled by something that I think should be basic. Would you mind putting an idiot on the right track, please?
If I create a route in Basecamp between points A & B, then tweak the Route Preferences and Avoidances to get the route I want, there are still only 2 waypoints - A & B. If I then transfer this to the Garmin (Zumo 660, if it matters), only points A & B get transferred and the Garmin then calculates the route it thinks, based on it's own settings, preferences and avoidances.
So, I thought I could convert the "tweaked" route in Basecamp into a Track and then transfer the Track to the Garmin, which would then take me the same way as in Basecamp. This doesn't seem to work
Now, I know about setting extra waypoints in Basecamp to make the route go where I want, but that's not my problem. How do I make the Garmin follow the route chosen by Basecamp, even if there are only 2 waypoints?
Hope someone can help
