dunnie
Please can anyone help???
I STILL have my 98 1100 and unfortunately she has suffered a technical hitch last night whilst out in torrential rain. Over the last few weeks the abs has not been setting itself because the battery was a little low. This was sorted using an optimate charger and bottomed out any abs faults.
However, last night whilst out in pooring rain I started the old girl up and was suprised that I could hear another electrical buzzer or motor spinning, the ABS set itself then all of a sudden the warning lights came on flashing alternately. I kept resetting the the warning lights until I got home which was about a thirty mile trip. To my suprise when I pulled up on the drive and turned her off I could still hear an electrical motor spinning, the noise was coming from under the tank, I removed all the fuses and relays but the noise remained and started to flatten the battery. I eventually disconnected the battery, which by now will need to be re-charged. I can only assume that there is a problem with the abs.
Am I right? Is it terminal? How do I fix it?Is it costly? I have looked at the Haynes manual which doesn't give any explanation about the spinning noise or possible abs faults, I wondered if I could dsconnect the abs and run without it for a while until I can afford the parts or whatever is required.
Hopefully somebody out there will know exactly what has happened to poor old "jessie", but for now she will have to remain semi naked in parts in the garage.
Please help, I can't afford for the old girl to die!!
On other relays I have unstuck 'em with a sharp tap to dislodge connections. The cover slides off as i remember. have a look...
