Had problems with my NAV6 this week. On a ride my satnav seemed to be having some sort of fit. It was scrolling and then started zooming in and out and then zooming right in to maximum and remaining on maximum. The touch screen was not responding. It then kept flashing up different way points. I disconnected it switched off and restarted. On turning back on I could get it to work normally again. But alas as soon as I set off the thing went into fit mode again.
On returning home I decided best thing to do would be to go into Garmin Express and check for software updates etc. Clean screen and see if that does the trick. .............
............and so begins my Garmin Express woes. For some reason it will not launch. Every time I click open nothing happens. It has been ok up until now. I have tried everything I can think of but still no launch. In the end I decided to uninstal Garmin Express and then restart the computer. I then done a fresh download of Garmin Express. It downloaded with no problems. Great methinks but when I clicked launch feck! the same thing has happened ie no launch.
I have systematically gone through the trouble shooting guide that is on the Garmin website (permissions/ administrator etc) there were five steps I think and I have done them all, but still the damn thing will not launch.
I have gone through the whole process above three times but still it will not launch.
My computer is running on windows 7. Is this the problem? Do I really need to buy a new computer with windows 10? It seems an expensive solution as other than Garmin Express my computer is working fine. Also I had no problems using Garmin Express about a month ago when I updated my maps. It was only this week when I had problems with my Nav6 which caused me to open Garmin Express that my problems started.
So after a couple of very frustrating days I am now at the
stage
Any help and advice for resolving Garmin Express will be much appreciated. As for my Nav6 I am hoping that I can sort that myself once I can launch Garmin Express (my firmware on my Nav6 is 5.8 by the way).
Here's hoping that a solution will come from you that will not involve a new computer. Cheers.
stageAny help and advice for resolving Garmin Express will be much appreciated. As for my Nav6 I am hoping that I can sort that myself once I can launch Garmin Express (my firmware on my Nav6 is 5.8 by the way).
