Maybe we should re torque every safety critical bolt as part of our pre-ride checks...
Japanese bikes do not seem to have the same problems?
I've always used a blob of er' indoors' nail varnish, and use it on every fixing I ever touch.
Probably does the same job, with or without glitter..........![]()
Yes, but without glitter, would it look fabulous?
I used Dykem tamper paint https://www.ebay.co.uk/itm/Dykem-C...ker-Nut-Bolt-For-Quick-Checking-/301687876472
It’s got lots of technical guff on the tubes and that price is for one tube
Just got some, life is worth more than 5 quid, cheers for the link, same Loctite stuff is over 30 quid
Have you done the front calipers too?
Nope I cannot see how them bolts can come out, without noticing, as I have a roadlok so see the front bolts quite often and easily, but when the tamper paint arrives, why not, bikes name will be mr Blobby............![]()
Make sure that you 'blob' every single spoke adjuster too as they can come loose and cause you to crash and die![]()
No spokes..........![]()
OK check your castings because there was some evidence that they are dodgy too.
Explain a little more, where did you see that.
And at the same time can someone explain how to ‘wire’ round bolts ?
