going backwards
bet my world
United Kingdom
Hi all, would anybody know if a fuel gauge which works perfectly in reverse- ie -when the tank is full it reads empty,lights flashing,and when its empty,read by the trip ,it reads full , no flashing lights. would this be a case of recalibrating or a new fuel strip?
thanks for any advice
b m world :confused:
Has a new fuel strip been fitted?
Has the existing gauge been giving strange readings? If so the carbon track inside the fuel strip is probably breaking down.
Try this:
http://forums.bmwmoa.org/showthread.php?69470-Fuel-strip-zapper
The Piezo pulse fuses together the broken ends of the carbon resistor strip. Its within the actual fuel strip so no sparks can get into the tank. But to be on the safe side do it with the tank full. No air = no oxygen so no ignition.
