GPS external high gain antenna
  • Thread starter Thread starter nadeem
nadeem
Fitted today on my bike and a friend's...with a shortened cable of 0.5m rather than the Garmin 3 metre job...
available from here
mine sitting on the windscreen bracket
friend's sitting on his motorrad concepts sat nav bracket
Well normally when I switch it on at home it takes 60-90 seconds to pick up a satellite - today it was under 30 secs...can't say more than that till I get a chance to test it properly.
Sounds like it helps, having a look at the "GPS Info" page with it in / out (fnarr fnarr) will I guess give an even better impression. At least with the aerial up front the blanking by the body should be less, I guess.
Nadeem:
May I respectfully recommend that you try and get that external antenna as horizontal as you possibly can?
If you go to the GPS satellite data page on your GPSR, and observe how the signal bars settle down with the antenna in its present (somewhat tilted) position, then you adjust the antenna so that it is as close to horizontal as you can get it, and have a second look at the signal strength bars, you will discover the reason why I recommend you try to keep it horizontal.
Those external antennas are designed on the assumption that they will be no more than 10° off horizontal. For that reason, no effort is made by the engineers who design them to optimize reception if the antenna is not horizontal.
Michael
Thanks Michael, I realise that...the chap did say that...will need to see what I can do about it when I get back from my weekend trip...what I might do is put it on top of the headlight...
Looks like you need one of those motorrad concepts mounts :D
Perhaps even better on top of the brake fluid reservoir
Agreed, that's where I put mine. FYI, the only reason I use the external antenna at all is because of the quite significant backwards tilt of the GPSR.
Michael
<a href="http://www.hostdub.com/PanEuropean:Remote_on_Moto_2720:full"><img src="http://www.hostdub.com/albums/PanEuropean/Remote_on_Moto_2720.jpg" alt="hostdub.com"></a>
That's precisely where I had mine until I had to rob my bike at Christmas for an antenna for SWMBO's i3 in her heat-shielded screened Peugeot 206.
:confused:
Greg
PanEuropean said:
Nadeem:
May I respectfully recommend that you try and get that external antenna as horizontal as you possibly can? Michael
I've done some testing on this and the importance of the orientation is huge. The internal antenna is designed to have fair reception independent of orientation. The external antenna gives better reception but it works ONLY if oriented perfectly horizontal!
