GPS III Power Supply
PIGGLET
N Yorks/Smoggville
I have a Garmin GPSIII plus which came with my bike which has a power cable with a fag lighter plug on the end. This plugs into an aftermarket accessory adaptor thing which is powered from the connector for the BM socket on the beak .
I would ideally like to do away with the accessory adaptor bank thing (looks like a blown fuse waiting to happen) and simply graft a BM plug on the end allowing it to be plugged into the BM accessory point on the beak.
I opened up the plug on the end of the garmin power lead in order to fit the new plug and found a circuit board, not the two wires i was expecting :eek:
Does this mean there is some sort of voltage reducer in there or can just graft the BM plug on the end of the lead and run it on 12V :nenau
