- Joined
- Jun 14, 2025
- Messages
- 2,207
- Reaction score
- 6,040
I've used Simply bearings for oddball stuff with no problems.
Seem reliable and also helpful
I tried one once as really liked the look but found the riding position for me was very uncomfortable. How are you finding it ?
Thanks for the reply , I have used them a few times before , its not the sourcing of the part I have the question with , that bit is easy , it is the suitability and longevity of a non OEM part in this application I have the concern over and hence my question . @theoneandonly what would you advise ?john,i have in the past used gateshead bearings ,they also do alsorts of seals etc, a brilliant local company to us ,and on the odd occasion they dont have what you want,they will do their best to get it for you
@nicholsonj2252
As long as the surface is unblemished and not grooved or abrasive I believe you would be fine with the Non OE
It is only for oil retention in an Unpressurised vessel Not a High pressure area
is there a breather and is it possibly blocked ? or is it just a bit of overfill dripping off ??
If you clean it with Brake cleaner and put a sheet of paper under it now does it re appear ??
The BMW R1150GS seal is a different size (10mm deep rather than 8mm) ??same seal as an 1150gs
@nicholsonj2252
Hi John , I got it from Gutsibits , link as per Fluffmeister's postThat's a lovely bit of kit John, do you mind me asking where you got it from? Asking as I fancy a can for my V85.
