katanamangler
Hi I picked up my GS1150 Adv on Saturday. It has 32k on the clock with service history. One of the previous owners had fitted a Y peice replacing the cat but the standard end can was fitted. The bike came with a remus end can the guy I bought it from had taken it off because he liked a quiet bike. I'm a great believer that loud piped save lives so I asked him to refit the Remus before I picked it up. I had to drive 250 miles home and for the most part the bike ran well a bit of popping on overrun but I put that down to the exhaust system. My real problem was in a higher gear 5th and 6th it seamed to be faltering around 4.5 to 5 thousand revs like it was starving for fuel if you rolled on it did clear and push through eventually but it was a pain in the arse for overtaking. I can t live it like that so I turned to google to find similar experiences.
Confident that it was the the y pipe and remus revolution to fault I tried the spade connector and wire mod on the cat code plug socket ( there was no plug in it. It made no difference ( maybe a bit worse)
I phoned the previous owner and he said he hadn't experienced the problem but he had run the standard pipe. So I changed to the standard pipe and it was still there ( mind you the standard end can was not what I would call an airtight fit should this have a gasket?)
I have lots of older bikes that need regular work and I bought this for the wife and I to do some miles on together I'm none too pleased and need some advice.
