GS-911 PC software update (beta)
ebbo
York
This looks good!
Revision History for GS-911 Beta 906.1
* Added support for the BMS-KP2 Engine control unit (most BMS-KP device are upgraded to this during the CD13.x forced software update when you take it to the dealership (fix for "Unknown Controller type").
* Added full Service and Maintenance support for all single cylinder Controllers (Output test for Fuel-pump, Injectors, Fan etc.) and Adaptation resets (Idle, Idle Actuator, Throttle Position, Lambda etc)
* Idle Actuator Calibration for all F-Series and K-Series CAN based models
* Idle Actuator Locking that is required for Engine (throttle body) synchronization
* Reset of "Distance to Next Valve Clearance Check" to default
* added support for the K1300 models
* Firmware update of GS-911 unit to v15
* some GUI enhancements
Login needed to access
http://www.hexcode.co.za/products/gs-911/beta/beta-1/document_view
Just remember its a beta, ok :)
It does look good - I'll be testing it out at the weekend when I do my 24k service. It'll save me having to remove the throttle body stepper motor connectors, at least ;)
